Old 09-09-2008, 06:12 PM   #1 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Article: Chevrolet Volt in final phase
Hello -
Here's another Volt update :
Autocar - Chevrolet Volt in final phase - 21 August 2008
When complete, the car will have a top speed around 100 mph, a 0-60 mph time of around 9.0 seconds, and a typical battery range of 40 miles, before the European-derived 1.4 litre four-cylinder "Family Zero" engine needs to be started to extend its range by generating more power.
The task now is simplify and miniaturise the components to fit a smaller, Astra-derived package, including a 180 kilogram T-shaped battery pack that fits along the transmission tunnel and under the rear seat. At around 1600kg the Volt is substantially heavier than an Astra, but its overall weight distribution is closer to 50:50.
Chevrolet Volt design chief Bob Boniface has revealed that the production car will look "a lot" like the original prototype, but will be more aerodynamic, with simplified surfaces, rounder corners, a lower roofline, a sealed grille, a minimised frontal area and "considerably better" all-round than the Toyota Prius.
The production Volt's aerodynamic performance improves on the concept by over "120 aerodynamic counts", the equivalent of reducing its mass by 120kg, or adding six miles to its range under electric power. The production model will carry enough fuel for a total range close to 400 miles.
CarloSW2
American Solar Energy Society
