Old 06-26-2019, 10:21 PM   #222 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
A little bit of progress!
The S2000 ebrake came today. It will require a little bit of modification to fit, but it should work well. The handle is a little shorter and higher than the stock one, and looks much better. Will be making an aluminum bracket to bolt it on since the holes do not line up between the two. That project will happen after I finish the rear carpet and get that meanwell unit installed tomorrow after arrival.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Ecky (06-26-2019)
