According to
Jalopnik.com, Volvo's new DRIVe line of vehicles to debut in Paris, is designed to reduce carbon emissions. How is this done? EcoMods, of course...
WhatCar.com
According to the site, the manufacturer is taking a...
Holistic approach to eco-performance
The reduction in fuel consumption and CO2 emissions was brought about by meticulously analysing the cars' total potential for more efficient, more economical driving. The cars were then optimised within four areas:
1. Reduced air resistance:
* Chassis height reduced by approximately 10mm to help reduce drag
* A front spoiler on the S40 and V50 which is the same spoiler currently on T5 models.
* Covered radiator grille. Behind the characteristic Volvo grille there is a wind-deflecting panel that provides better aerodynamics inside the engine compartment.
* Wind deflectors in front of the front wheels to steer the airflow.
* Aerodynamically optimised wheels with a unique ‘Libra’ rim. The diamond cut finish adds to the unique design and the large unobstructed area that goes all the way out to the tyre makes the rim look considerable larger than it actually is. The total drag reduction of 10-15% is due to the design of the Libra rim.
* Underbody panels on the Volvo C30 for more efficient airflow under the car.
* A unique rear spoiler has been developed for the Volvo C30 which adds both to the aerodynamics and to the visual appearance. The Volvo S40 features the same ‘ducktail’ spoiler as found on the current T5 and D5 models.
* New rear bumper on the Volvo C30.
2. Lower rolling resistance:
* All the cars are equipped with a new generation of Michelin tyres with low rolling resistance.
3. Higher ratios:
* Gearbox with altered ratios for third, fourth and fifth gears. The longer gear ratios contribute to a 1.5% reduction in fuel consumption without affecting the drivability of the car.
4. More efficient driveline:
* Optimised engine cooling, engine management and power steering.
* New transmission oil which creates much lower friction will be used in the gearbox.
* Gearchange indicator in the information display to tell the driver the ideal time to change gears."
The question: When will the rest of the world catch up?
RH77
