Old 09-09-2008, 09:55 PM   #19 (permalink)
Frank Lee
I've had good success with what I call "engine blankets". I use corrugated cardboard or foam board insulation, whatever fits, in conjunction with a winter-only grille block. Basically, when I open the hood, all I see is the engine blanket covering the entire compartment. It really helps heat retention. I noticed much faster warm-ups. Can't quantify the fe improvement but it had to have helped.
