Old 09-09-2008, 01:45 PM   #11 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
I think the law probably says its illegal to stay in neutral.
Because if some one turns out infront of you on a hill, or isn't stopping behind you at a light you can't accelerate quickly to avoid an accident if your in neutral.
(Politicians logic)
Old 09-09-2008, 01:47 PM   #12 (permalink)
want to do
Originally Posted by Mr_C View Post
aerohead:
I agree, I will never be able to get summertime mileage in the winter, but I want to do anything I can to try to minimize damage. I won't be doing much modding this winter because it is too darn cold to want to be out there anyway. My big problem (and the large majority of my miles) is my 35 mile daily commute. In the summer it is a gallon in my car, or a half gallon on my bike, it is a lot more than a gallon in the winter.
modmonster:
Thats a good point. I didn't add that at all. I have a significant grill block already (I tried a full grill block in the summer, bad idea). I should block it all the way once it gets a little cooler. I put a grill block on my truck too with a "cold front" that I think makes a difference.
Tango Charlie:
I have been lurking for about a month or so.. just trying to get as much info as I can. I have learned a LOT from reading all the aerodynamics stuff... and while the pulse & glide stuff seems counter intuative to me, I have found it works pretty well in town. When it gets COLD (-20 F) my mileage drops 20% or more. But even now when the morning temps are in the 40s (recent cold snap) I am noticing that I am not getting the same instant mileage at 55 that I was before. Argh...
-Mr_C
Here's some thoughts, that if IC Engines survive into the near future,we might do to minimize winter losses.Your car would have electric pre-heat for coolant,engine oil,transmission oil(fluid),and rear differential(if rear wheel drive).The engine,transmission/transaxle,or differential,and exhaust system would be wrapped in a thermal insulation jacket.Renewably-sourced electricity would be used to pre-heat the car before travel.Once at your destination the engine compartment would be completely sealed off from the environment,via closing dampers,and the insulation would attempt to hold the precious heat within the engine and complete powertrain components.Or the car could be plugged in at work,to aid "cold-start" for the commute home.This would displace some of the energy to the "cleaner" grid.Since most pollution occurs within the first 2-minutes of cold-start it would be a boon to air quality,and aside from cold tires(75-degrees F is considered cold by the EPA)the car would never experience "cold-start"again,and savings the the US alone would be measured in the billions.-------------------- I don't know how to get around the issue of the tires.The super LRR tires created for the concept cars might help.Perhaps the US Govt. could purchase the patent for this technology,and make it available,license-free,to any tire-maker interested in producing them.Cold,these tires would have no more RR than fully-warmed conventional all-season steel radials.No technological barriers,something else going on there.Aside from the LRR tires,ecomodders would be free to pursue anything else,as they would only be limited by their own ingenuity.
Old 09-09-2008, 01:49 PM   #13 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
to me, same thing apply's to a manual tranny. I can pop the shifter on my auto jeep and hit the gas faster than I can let off the clutch, turn and gas it all at the same time without accidentally killing it from the adrenaline.
Honestly, there are some pretty dumb laws out there, especially in IL.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 09-09-2008, 02:57 PM   #14 (permalink)
Lex - '02 Lexus IS300 Sedan
90 day: 19.77 mpg (US)
Turblow - '88 Mazda 323 GTX
Subie - '96 Subaru Impreza Outback
90 day: 21.15 mpg (US)
Lets not forget about Winter vs Summer blends of gasoline too!
Old 09-09-2008, 04:41 PM   #15 (permalink)
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
What's the difference? Do you have some good reading about it? I knew there was a difference...never sure what it was, though.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
Old 09-09-2008, 05:51 PM   #16 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
LINK. I never knew there really was a difference...
Old 09-09-2008, 06:06 PM   #17 (permalink)
ptsmith24's Avatar
Thanks.
Old 09-09-2008, 08:32 PM   #18 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Remember that "rho" factor in the equation for aero drag. "Rho" is the density of the air.
Cold winter air can be up to 20% denser than warm, humid air, hence more aero drag in winter.
People drive differently in winter. Not getting stuck is kinda important. Also on slick roads you have to put much more emphasis on avoiding bent-up sheet metal. For me that cuts down on my coasting.
Solution: Move to Houston.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-09-2008, 09:55 PM   #19 (permalink)
I've had good success with what I call "engine blankets". I use corrugated cardboard or foam board insulation, whatever fits, in conjunction with a winter-only grille block. Basically, when I open the hood, all I see is the engine blanket covering the entire compartment. It really helps heat retention. I noticed much faster warm-ups. Can't quantify the fe improvement but it had to have helped.
Old 09-09-2008, 10:45 PM   #20 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
you don't leave that "insulation" in while you are driving around do you?
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
make the car heavier to gain mileage?! bgd73 EcoModding Central 5 07-07-2008 06:33 PM
