Originally Posted by Snax
... I did some quick low speed testing at two different tire pressures, and long story short; there isn't much 'fruit' there....
You will want to consult MetroMPG's test:
https://ecomodder.com/forum/showthre...html#post30483
And Mythbusters TV testing results (confirmed MetroMPG's results):
https://ecomodder.com/forum/showthre...tml#post235681
You might save yourself some frustration by aggressively using the search function on the EM page (upper left corner). There are lots of discussions about issues you are raising. Some really good testing too.
A key image from MetroMPG's test results report:
![](http://metrompg.com/posts/photos/metro-to-scale-1200.jpg)
