Old 07-13-2019, 07:23 PM   #6190 (permalink)
freebeard
Here's some additional research (From S0 today)
Originally Posted by S0
...let's come
up to the satellite level for the fire
carbon run this is only the carbon
releases from fire activity around the
world link to the video is below and as
a reminder it always surprises them to
find out how much of the carbon
contribution is natural
compared to humans...
https://svs.gsfc.nasa.gov/4728
https://svs.gsfc.nasa.gov/vis/a00000...te_1080p30.mp4
________
Vast rings of electrically charged particles encircle the Earth and other planets. Now, a team of scientists has completed research into waves that travel through this magnetic, electrically charged environment, known as the magnetosphere, deepening understanding of the region and its interaction with our own planet, and opening up new ways to study other planets across the galaxy.
Kim and researchers from Andrews University in Michigan and Kyung Hee University in South Korea focused their research on mode conversion, the way in which some EMIC waves form. During this process, other waves that compress along the direction they travel from outer space collide with Earth’s magnetosphere and trigger the formation of EMIC waves, which then zoom off at a particular angle and polarization — the direction in which all of the light waves are vibrating.
Using PPPL computers, the scientists performed simulations showing that these mode-converted EMIC waves can propagate through the magnetosphere along magnetic field lines at a normal angle that is less than 90 degrees, in relation to the border of the region with space. Knowing such characteristics enables physicists to identify EMIC waves and gather information about the magnetosphere with limited initial information.
Moreover, engineers employ waves similar to EMIC waves to aid the heating of plasma in doughnut-shaped magnetic fusion devices known as tokamaks. So, studying the behavior of the waves in the magnetosphere could deepen insight into the creation of fusion energy, which takes place when plasma particles collide to form heavier particles. Scientists around the world seek to replicate fusion on Earth for a virtually inexhaustible supply of power to generate electricity.
Knowledge of EMIC waves could thus provide wide-ranging benefits. “We are really eager to understand the magnetosphere and how it mediates the effect that space weather has on our planet,” said Kim. “Being able to use EMIC waves as diagnostics would be very helpful.”
Princeton Plasma Physice laboratory: scientists-deepen-understanding-magnetic-fields-surround-earth-and-other-planets
The wages of woke is broke[™] -- Harvey Cthulhu
aerohead (07-17-2019)
