Old 07-15-2019, 12:12 PM   #32 (permalink)
Taylor95
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Originally Posted by RustyLugNut View Post
I'm not sure how it is in your neck of the woods, but here in Southern California they are plentiful. You can pick up a runner for 1000 dollars.
Our laws allow you to swap a diesel into your pre-1997 inclusive, Jeep and not have to run smog checks. With the older, robust pumps on these diesels, you can run waste oils to reduce your fuel costs. There are several companies that make adapter kits for the Mercedes OM617 and OM602-3 line of engines. I make my own as I have a fabrication capability and CNC equipment. These diesels have good RPM capability so they cruise on the freeway comfortably. The Cummins 3.9 does provide more torque but they weigh much more.
Look into it and see the availability in your area.
There are no mercedes turbo diesel cars in my area. There seems to be a lot in California though. That would only be a couple hour drive, so it may be worth it. It might be easier than finding a TDI engine to swap in, though I didn't find any here either. We have a big food truck culture here, so finding a box van with the Cummins is a possibility.
Also CPM calculators seem to be more of a marketing thing. I could not find anything for cars.
