Old 07-17-2019, 05:21 PM   #6203 (permalink)
freebeard
Is Demeo the latest stand-up comedian? Do you actually believe that you could possibly quantify such a thing? He's a moron.Arguing how many angels that can dance on the head of a pin.
Not a comedian. A sociological researcher/scientist tarred with the same brush as Wilhem Reich. I have no opinion on who the moron is in this situation.
How do you quantify such a thing? You take the most extensive data sets available for research and map it globally, over time, at a finer granularity than anyone else has attempted.
Then you offer a trend analysis that matches the historical record and suffer ad hominem attacks. If your getting flak you know you're over the target.
You do need a top-secret security clearance to know what's really behind 'officialdom.'
Else you monitor open sources and know everything they know, by their actions. 'Oficialdom' is reduced in the current security environment to passing communications in the clear, on 8chan.
The choice to know will be yours.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
aerohead (07-20-2019)
