Old 07-24-2019, 03:02 PM   #2 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
One general warning about coro discs (from experience): keep the edge of the disc off the tire itself. It's sharper than you might think, and over time can cut into the rubber if it's in contact, even at a shallow angle.
Here's one of several iterations I've done:
The Premier's Limo: 2004 Toyota Prius "winter beater" ecomodding thread
In this case, I drilled into the OEM plastic trim ring that goes on the OEM alloy wheels. Here's the trim ring:
The Following 7 Users Say Thank You to MetroMPG For This Useful Post:
Cd (10-09-2020), Coreyosaur (11-20-2019), Daox (07-28-2019), Lemmy (07-28-2019), razordave (08-04-2023), Snax (07-24-2019), Xist (01-06-2020)
