Old 07-25-2019, 07:31 PM   #1 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
2020 Silverado Diesel 3.0 EPA Rated...
...33 mpg highway--pretty phenomenal for a truck! Here's Chevy's press release: https://media.gm.com/media/us/en/che...silverado.html
-The inline-six engine provides an inherently balanced configuration for low noise and vibration characteristics. It features an aluminum block for weight reduction, an 84mm x 90mm bore and stroke, dual-overhead camshafts and four valves per cylinder.
-A new active thermal management system warms up propulsion components more quickly for more efficient operation.
-The exhaust brake, which is available in tow-haul mode, can provide additional driver confidence when towing, especially when going downhill.
-The driver-selectable stop/start technology enhances fuel economy by shutting off the engine at stoplights and certain other stop-and-go situations, helping save fuel. The engine automatically restarts when the driver takes his or her foot off the brake.
-The 3.0L Duramax is exclusively paired with a Hydra-Matic 10L80 10-speed automatic transmission, featuring smaller gear steps and an overall larger ratio spread to enable peak efficiency. Intelligent controls adjust to the driver’s needs for smooth operation and aggressive response.
It's unclear whether there were any aerodynamic changes for this model specifically; the release quotes the chief engineer as saying it's "more aerodynamic than before" but doesn't clarify whether that's the diesel compared to the gas version or the truck overall, which of course was all-new for 2019.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Hersbird (07-26-2019)
