Old 07-28-2019, 09:00 AM   #12 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I wanted taller than stock rims that were also lighter, so I ended up with 15" 2007 BMW MINI seven hole rims (12 lbs). For a cover I blanked the holes from behind to create a "flat" surface preventing airflow THROUGH the rim face. This should prevent almost as much wheel drag as smooth covers while keeping my overall weight to about 12.5 lbs per wheel. Smooth covers would do slightly better but they tend to go onto heavier wheels, to which the cover itself adds weight.
Here is some of the data behind the thought behind blanking lightweight rims:
Here is the look:
CITATIONS:
This is mostly a reposting of post #421 in my own modding thread (see link in sig file below).
"AEROHEAD" opinion cite... somewhere on ecomodder.com I swear it.
Alexey Vdovin, "Investigation of Aerodynamic Resistance of Rotating Wheels on Passenger Cars," (Gothenburg, Sweden: Department of Applied Mechanics, CHALMERS UNIVERSITY OF TECHNOLOGY, 2013).
http://publications.lib.chalmers.se/...302/176302.pdf
See also:
http://publications.lib.chalmers.se/...ext/133661.pdf
"Blocking the crossflow through the rims result in increased static pressure in the front wheel house and thereby an increase in lift, whereas blocking the crossflow in the rear result in increased downforce due to an increased flow rate through the diffuser. It was however shown that the resulting flow around the rear wheel was highly dependent of the rim design in the front."
The Following 4 Users Say Thank You to California98Civic For This Useful Post:
conor_v (07-28-2019), Daox (07-28-2019), RedDevil (11-04-2019), Snax (07-28-2019)
