Originally Posted by ugr
Front end is in good shape, as is alignment and brakes. Haven't checked out the exhaust or the shocks, but I haven't experienced any problems with that. I see people getting 18-20 so I am not shooting for crazy numbers, just a little bit higher...
In that range,
a bit higher still translates to a fair bit of gas.
Forget the aero stuff
A brick will remain a brick unless you do massive aerodynamic modifications - on the rear .
Driving habits are going to be your best bet.
https://ecomodder.com/forum/EM-hyper...ecodriving.php
Move it less & combine trips
Drive a bit slower - if you don't already
Drive with load, and as if without brakes
Pump up the tires
