Old 08-15-2019, 12:24 AM   #913 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
Originally Posted by mpg_numbers_guy View Post
Are you hauling heavier loads now with the bigger engine? Any stressing on the frame components?
I don't know the capacity of my hitch, but luckily I haven't hit it. I inspect before and after towing every time and so far it seems to be holding everything I throw at it, but I'm also careful. I found I could pretty much haul whatever I wanted even before the engine swap, I just needed to use a lower gear. The new engine, if anything, makes me more reluctant as I fear I might accidentally pull the back of the car off if I lay on the throttle.
