Some pictures
2.5" spacer with front passage blocked to send all air through 1 of 2 passages giving the air more velosity/ energy to act apon the turbine.
2.5 diverter test piece installed on the S366/80 .80 AR
The diverter valve after getting proof of concept with the test piece
Diverter valve mocked up with hx35 on a DAP t3 manifold that I traded for the 3rd gen manifold that came in the turbo kit I got
A compairison of the 3 turbos
compairing the backs
I also had the 300k mi+ injectors tested and pop presher adjusted . All but #5 were down to 209 bar(3031psi) pop pressure #5 was 220bar(3190psi) now 4 are 258 and 2 at 256 (3741and 3712psi respectively) I put the 2 lower in cylinders and 4 because theas are the leanest cylinders and the minimal extra fuel/timing they will get form lower pop pressure will help to balance the crank loading. This has retarded the timing ~ 5°(1°/ 10bar pop pressure change) so to day I'll adjust the timing. The advice on line is to bump the timing 1/8"(3-5° )
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
