not be good
The only thing I'd mention would be the angle of the diffuser.You may need it to be that steep to protect it from ground strikes,while rolling up or down driveway ramps.If not,lowering it might cut drag a bit more.4-degrees is the maximum for a 'short' diffuser.2.8-degrees for 'long.'
