Take the cost to put just 1kg on space.
Take to convertion efficience of IR laser to electricity, and als the loss from atmosphere.
No way, this idea would be thousand times more expensive than solar panels on surface.
Edited: Take also the fuel rockets needs to put a single solar cell on space. A rocket uses many tons of fuel to put small objects on space. This is, in relation, more energy than the cells of thousand solar panels on space would be able to generate in their lifespan.
Originally Posted by sendler
CalTech is working on an orbital space based solar electricity scheme using microwaves to transmit the power back to Earth with banks of millions of these 10 cm tiles. I am surprised to hear that most of the research in the USA and in China is still headed in this direction. Microwave power from orbit requires a 1:10 ratio of antenna diameter. To keep the energy levels on the ground to levels that are comparable with what we are exposed to from the sun (in case the aiming goes astray and starts shining on a city before we can shut it down), 0.75 GigaWatt requires a 1 km diameter assembly of these tiles in orbit, all aimed with micro radian precision, onto a 10 km receiving antenna on the ground. After learning about the scale of the antenna requirements versus the total power they could transmit, I was immediately convinced that transmitting via lasers would be much better and would make any future ground based standard solar panel installations forward compatible with just perhaps the inclusion of adjustable tilt and single axis tracking which are beneficial for maximizing sunlight anyway. https://youtu.be/KtNwYweL6hY
