Old 09-03-2019, 01:14 PM   #226 (permalink)
Daox
I believe the Mitsubishi I-MiEV and Honda Fit EV use lithium titanate for their battery. It's been around for quite some time. I believe energy density is lower, but the cycles it can handle are crazy high. Cell voltage is 2.3V nominal so you need ~30% more cells for the same voltage with lithium ion.
The Following User Says Thank You to Daox For This Useful Post:
NeilBlanchard (09-03-2019)
