Old 09-05-2019, 09:34 AM   #711 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by Tahoe_Hybrid View Post
if any one really really wants to do a hybrid swap i suggest getting one from a 2mode Hybrid
available in Hemi and LS2 (LS2 based aluminium block) flavors...
both V8 engines you will get about 25-30 mpg or so in a car
it's pretty much a drop in upgrade. for any RWD .. might need a STRONGER drive shaft though
these 2modes use a 4" drive shaft .. due to the massive amount of torque..
other wise you will end up twisting up your nuts and bolts
I originally considered using the system out of a hybrid Tahoe, but it wouldn't have given me nearly the 50+ mpg that the Prius system will.
The Following User Says Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020)
