Old 09-10-2019, 06:26 AM   #2 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I can't speak for towing, but in most vehicles, going with taller gearing improves economy all the way up to the point that you can't maintain speed in that gear anymore - and then you just downshift.
In my car I picked the tallest 6th available from any model (usually paired with shorter final drives) and had a custom final drive cut which was 30% taller than anything OEM. I also upsized my tires slightly. Going even taller would help even more, but my low gears might need to be changed so they're a little closer together to keep it fun when I want to waste fuel.
