Hi Jonisingt35r! I can't keep all the names straight of stuff either. Don't even worry about it. I did a controller for an asynchronous and synchronous motor, but I've only done quite a bit of testing on the synchronous motor under load, not the asynchronous motor. I've only ever tested asynchronous motors NOT under load. Well, a friend tested his tesla motor while hooked up to a gear box, and it seemed to work fine, but I don't know about driving around with it.
