Old 06-13-2019, 11:39 AM   #3401 (permalink)
I'm happy to see you are back "in the game"!!
Looking forward to getting back to work on the controller whenever you are ready, though I might just have to get a Leaf motor (instead of the AC51 I have now) since everyone is moving in that direction anyway.
Old 07-06-2019, 01:40 AM   #3402 (permalink)
PaulH
MPaulHolmes's Avatar
I've almost got a dyno set up. Very soon there will be lots of testing that can be done. Here's a picture from earlier this week.
kits and boards
The Following 3 Users Say Thank You to MPaulHolmes For This Useful Post:
59Morris (07-06-2019), freebeard (07-06-2019), thingstodo (07-07-2019)
Old 07-23-2019, 06:44 PM   #3403 (permalink)
PaulH
Here's a quick demonstration of the dyno with one motor running in torque mode, and the other running in speed mode. I'm getting some really great data, too. The big question I had was about finding the motor's saliency, and how to automate that later. The motor's "current" can be represented as:
<Id,Iq>, where the 2 currents are at 90 electrical degrees to each other, and the current command is
currentCommand = sqrt(Id*Id + Iq*Iq).
The trick is to figure out how the current command should be divvy'd up between Id and Iq. Think of it as a right triangle. The hypotenuse is the current command, and Id & Iq are the 2 other sides of the triangle. CurrentCommand can be mostly Id, or mostly Iq, or somewhere in between. I have been varying Id from 0 up to currentCommand, and looking at how big currentCommand is in order to maintain the constant speed. The <Id,Iq> combo you want is the one that results in the smallest possible currentCommand, which means you are getting the biggest torque per amp of motor current. The ratio of Id to the currentCommand changes as the current command increases.
kits and boards
The Following 4 Users Say Thank You to MPaulHolmes For This Useful Post:
59Morris (07-23-2019), LouMan (05-11-2020), ocnorb (07-24-2019), thingstodo (07-24-2019)
Old 09-01-2019, 11:20 PM   #3404 (permalink)
PaulH
EBike first test with diy controller
Here's a first test with a TO-247 mosfet controller.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
LouMan (05-11-2020), thingstodo (09-02-2019)
Old 09-02-2019, 05:22 PM   #3405 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Good progress on your proto-type!
I'll echo the questions I saw posted on the youtube video - Are you thinking of a kit, a or bare board with a BOM to solder onto? If so, I'll take 3
Why? I have 4 SEVCON mosfet-based AC controllers that are in need of repair. ... and the cases are too small for the larger AC control board to fix. But they need brain transplants if I can drive the MOSFETs.
3 of them have kinda strange fault codes - motor temp too high, low bus voltage, encoder faults, etc. The brain transplant should avoid the cold solders, corrosion, and various other possible problems.
The last one is complaining about a power stage problem so it may have actual problems that I can't fix with a brain transplant.
It would be easiest (for me) to have a new driver board and a new control board. I might be able to re-use the driver stages ... but that could be where I am having the issues
I was going to use your larger AC controller. And I blew one set of IGBT's by reversing + and - on the battery back ... newbie mistake! ... and I have not gotten back to the project since.
But ... a controller board that will fit inside the case (or looks like it might) would help a bunch. And driving the existing MOSFETs would also help since they appear to be in good shape, and it makes my mechanical how-do-I-make-it-fit challenges smaller
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 09-02-2019, 05:24 PM   #3406 (permalink)
BTW Paul, there is a member looking for the gerber files for you ReVolt (that was the cougar, right?). It looks like I don't have those
https://ecomodder.com/forum/showthre...tml#post605654
Old 09-08-2019, 07:40 AM   #3407 (permalink)
Looking for a good controller
Hello
Im looking to build an ev, and i am looming to build an ooen source controller for an ev
Car.
Just wondering is this one is realiable and has good documintaion ect
I would like to go ac route, rather than dc really as i have lots of experience with inverters
Tbh both routes have their advantages dc, low cost, just after a realiable controller i
soppose.
Would really like to buils an ac inverter as im also interested in solar as well
I see this has been going now since 2008 hope its still running, or maby if its not is there another controller out there open source?
Thank you
Old 09-13-2019, 11:36 AM   #3408 (permalink)
PaulH
Hi Jonisingt35r! I can't keep all the names straight of stuff either. Don't even worry about it. I did a controller for an asynchronous and synchronous motor, but I've only done quite a bit of testing on the synchronous motor under load, not the asynchronous motor. I've only ever tested asynchronous motors NOT under load. Well, a friend tested his tesla motor while hooked up to a gear box, and it seemed to work fine, but I don't know about driving around with it.
kits and boards
Old 10-03-2019, 04:50 PM   #3409 (permalink)
3 PHASE AC INDUCTION MOTOR CONTROLLER
I hope all are doing great. I am planing to covert my honda city to electric. Previously I have done dc conversion using open revolt motor controller(thanks paul) now I am looking for ac conversion. can someone please send me gerber file and other details regarding Paul 3 phase ac controller. That will be a great help
email - vivek.naw@ live.com
Old 05-08-2020, 06:08 PM   #3410 (permalink)
Introduction and request for help
Hi all,
I'd like to share my progress on my inverter build. I bought a bare board about 18months ago (yeah, i know), and following the instructables, paul's documents and this thread, I finally have what seems to be a functioning inverter. I've followed Paul's instructions almost to the letter, including which current sensors, capacitors etc to buy, even down to the design of the housing and copper plates. The inverter is tested using every test I've read, and it appears to function correctly!
I've attached some photos.
I'm using a lexus GS450H motor as a test motor, and I'm having trouble getting it to spin using the throttle. This is a permanent magnet motor, with an rx-8 hall-effect throttle, and a 48v (nominal) pack
The main values i'm changing to tune are KP/KI, the throttle values (min, max throttle & regen) and angle-offset. Are there any more that I'm not aware of?
So what am i seeing:
  1. The throttle seems to have no effect, but I can see the raw values change as expected when streaming (values change from ~315 -> ~800). I've tried every combination of throttle settings I can think of, but with no luck.
  2. Running the run-pi-test2 produces inconsistent results: the motor turns briefly (maybe 45 or 90 degrees) when the test is run, and sometimes converges to near 0, but it doesn't converge every time i run it for any settings i use. So when i *think* I've found good values but then it doesn't converge a minute later.
  3. The run-angle-offset-test causes the motor to run smoothly (between angles 140->240), so the inverter is capable of running the motor smoothly. I just cannot make this happen using the throttle.
So my questions:
  1. For a given KI and KP, should I see a response from the throttle, even if it's a small movement of the shaft?
  2. Are KI, KP and angle-offset related to such an extent that they would cause no response from the throttle if it's set up wrong? In other words, which numbers are most important to mess with to verify that I can get ANY response from the throttle.
  3. Is there a test I can run which proves / disproves that throttle response is / is not working?
Sorry for the long post, but this thread has been amazing help, and I hope to contribute in future.
ID:	28087   Click image for larger version
ID:	28088   Click image for larger version
The Following User Says Thank You to sparkey For This Useful Post:
freebeard (05-08-2020)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
