Old 09-18-2019, 11:57 AM   #31 (permalink)
cajunfj40
Lurking Eco-wall-o-texter
Good thing is that part of the system (everything motor, turbo, exhaust, emissions) has a 4 year 46000 mile warranty from my purchase date (whenever that may be) or 10 years 120,000 miles from manufacturing whatever is longer. One of the ones I am leaning to is a 2012 with 68,000 miles on it. The dealer I'm working with also adds the lifetime powertrain as long as you do whatever VW preventative calls for for oil changes and transmission services at any ASE service center.
Hello again Hersbird,
Ah, if that part is actually covered (my Dad's wasn't, IIRC, and it was not out of warranty as far as I know - he didn't keep it as long as he usually does. I can't help but think he would not have been so annoyed if it had been covered.) then you're good at least on the cost front. Do note the warning about the AdBlue though, if it is empty or doesn't work right (according to what the sensors tell the engine computer, anyway - and it can tell if you used something other than AdBlue!) it'll eventually give you a 600 mile countdown timer to no-restart.
Oh, and I don't recall exactly whether that particular engine has the issue, but there's something picky about the oil specification - if the TDI you get is one of the picky ones, not using the right VW oil spec (not a regular industry spec, a one-off like GM's Dexos or whatever) it eats the cam or something.
Aside from all that, it should be a great distance-cruiser tow-beast! I was interested in the previous model that still had low range (through 2009 IIRC) but it's hard to find the diff locks in the US and, more importantly, my primary commute is 11 miles one way, which isn't great for a diesel in winter.
