Old 09-12-2008, 12:10 PM   #669 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Originally Posted by ptsmith24 View Post
Does it stay at 1 or 2 mph? Or does it eventually go down?
If I come to a stop and it is reading 0.98 mph, it just stays there. It doesn't look like it factors into the iMPG calculation, since that is at 0.00 mpg, but my question would be if it would screw up the "idle gallons" since it's displaying that it's moving. I should also add that this was happening when I was running v0.70.
Question:
How is the EOC miles being calculated? Is it based on a VSS signal and no Injector signal, or is it based on an iMPG of 999999? Lots of times when I EOC, I get a reading more like 298929 (and it holds constant there), which is HUGE, but could screw with things if it's not programeed correctly. If it's based on iMPG perhaps we could say any reading over 1000 mpg is "EOC".
Question:
How much power does this thing use when the car is off? On my iDuino board, the two LED's stay on all the time, I know that doesn't use much, but it must be using something. Thanks.
