Old 10-04-2019, 07:57 AM   #8 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
You might try slightly higher pressure, if you're comfortable with it. I run 50 in the tires on my Insight - they have a 50 PSI max sidewall rating, which as I understand is not actually a max pressure rating, but the pressure needed to carry their maximum load.
Definitely recommend an MPGuino, it's nearly essential.
