Old 10-08-2019, 12:54 AM   #34 (permalink)
freebeard
teoman — Don't forget to post about any results. I've identified an opportunity myself. I'm holding a low reservation number for one of these:
I want to substitute a steel VW wheel for the two fronts so that I can used Moon disks. Then I want to bend a circular strip of dielectric material into a conic section and attach it to the outer rear edge of the front fender. With a thick copper wire bent into a serpentine on the outside leading edge and the other behind the trailing edge.
Best case it would blow a sheet of air against the main body, to re-attach the turbulence coming from the A-arm suspension.
It's an electric vehicle, so power supply is no problem.
You can't be wise and in love at the same time. -- Bob Dylan
