Old 09-30-2019, 08:18 PM   #31 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Tuft testing?
The Following User Says Thank You to teoman For This Useful Post:
freebeard (09-30-2019)
Old 10-03-2019, 10:04 AM   #32 (permalink)
Plasma is such a drag.
Ayaks
https://en.wikipedia.org/wiki/Ayaks
Plasma sheath
As altitude increases, the electrical resistance of air decreases according to Paschen's law. The air at the nose of Ayaks is ionized. Besides e-beams and HF pulse discharges, a high voltage is produced by the Hall effect in the MHD generator that allows a planar glow discharge to be emitted from the sharp nose of the aircraft and the thin leading edges of its wings, by a St. Elmo's fire effect. Such a plasma cushion in front and around the aircraft offers several advantages:[35][36][2]
The ionized air becomes electrically conductive, which allows the MHD generator to work and decelerate the flow down to the air-breathing jet engines.
The MHD-controlled inlet ramp allows to vector the flow as a shock-on-lip without physical inlet cones.
Electric charges mixed with the fuel increase the combustion effectiveness.
The bow shock wave is detached further ahead of the aircraft, the energy deposition in this region acting as a virtual blunted nose, although the nose stays physically very sharp. This minimizes the heat flux on materials.[35]
The temperature gradient in the air is locally modified, hence the speed of sound value, which mitigates and softens the shock wave. This lowers thermal effects on materials further, as well as the wave drag.[37][38][35]
The plasma cocoon surrounding the whole aircraft gives plasma stealth. Combined with hypersonic speeds and maneuverability, such a platform would be very difficult to detect, track and target
Magnetohydrodynamics?
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
freebeard (10-03-2019)
Old 10-04-2019, 12:41 PM   #33 (permalink)
Feng sui is indistinguishable from fluid dynamics.
2000 F250 7.3 CC 20+ MPG @ 10000 #
2013 Golf tdi 47.5 mpg neutered, 1500 mi beer run
1988 Ranger EV Volt batts>> 18,000 MPG and climbing. Rag overhaul.
Old 10-08-2019, 01:54 AM   #34 (permalink)
teoman — Don't forget to post about any results. I've identified an opportunity myself. I'm holding a low reservation number for one of these:
I want to substitute a steel VW wheel for the two fronts so that I can used Moon disks. Then I want to bend a circular strip of dielectric material into a conic section and attach it to the outer rear edge of the front fender. With a thick copper wire bent into a serpentine on the outside leading edge and the other behind the trailing edge.
Best case it would blow a sheet of air against the main body, to re-attach the turbulence coming from the A-arm suspension.
It's an electric vehicle, so power supply is no problem.
God's blessing on this wonderful world!
_________________
Old 10-08-2019, 11:30 AM   #35 (permalink)
The power supply will promise to be annoying and inefficient. I do have concerns about plasma and the general public being in close proximity.
Old 10-08-2019, 01:33 PM   #36 (permalink)
EcoModding Newb
90 day: 28.07 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 28.08 mpg (US)
I looked at that website and understand the concept, but is it really plasma? Seemed to be ionized air, which doesn't fit the definition of plasma. I'd expect ionizing air to be less energy intensive as creating plasma.
Old 10-08-2019, 01:56 PM   #37 (permalink)
The gating factor would be whether the aero improvement would pay for itself and not reduce range.
It would be inefficient to switch it on below 25mph. Above 25mph there would be other concerns.
edit: No true plasma fallacy
Originally Posted by Wikipedia
Plasma - physics
Plasma is one of the four fundamental states of matter, and was first described by chemist Irving Langmuir in the 1920s. It consists of a gas of ions, atoms which have some of their orbital electrons removed, and free electrons.
A gas of plasma is poor wording.
_________________
Copyright ©2000 - 2019, vBulletin Solutions Inc.
