Old 10-10-2019, 10:25 PM   #61 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
OK! Sensible mods:
1) Got a ScanGauge or equivalent?
2) You need to get a block heater in there. You won't get top gear (or torque converter lockup) until the coolant at a certain threshold.
3) Grille blocking to improve aero, warm-up times & heat retention.
4) How's your PSI?
5) Anybody else?
I think you covered it. Personally I wouldn't spend much money modifying a $750 car with 200K miles. Drive it and do the maintenance required to keep it safe and reliable. The items you list are cheap and give good results for the minimal cash spent.
If the OP wanted to spend lots of time but little money an underbelly pan made of discarded political signs could be an option.
#1 for me would be a good set of 4 winter tires on used wheels.
The Following User Says Thank You to JSH For This Useful Post:
redpoint5 (10-11-2019)
