GK13 - did you do any mods yet?
I'm curious why you're interested in taller tires? If it's for gearing, I doubt you'd gain any advantage there as the eCVT generally aims for lowest engine RPM under low load conditions regardless of cruising speed (notwithstanding generator requirements to charge the hybrid pack). I suppose at some point you would max out the gearing range at high speed.
Also, raising the ride height will likely increase drag some.
