Old 10-11-2019, 10:25 PM   #16 (permalink)
cRiPpLe_rOoStEr
If getting your project on as many blogs/forums/sites as possible is the goal, then a manual transmission diesel drivetrain in a Prius is unquestionably the way to go.
Also, it'd be pretty fun to see what kind of numbers you could get -- Prius Cd is 0.24-0.25 if memory serves, and frontal area is probably similar to the Golf. Do a few more well-known aero mods to it and you could be knocking MPG out of the park with a sufficiently tall top gear taking advantage of the low drag.
Not so sure if a manual would really be the way to go. Easier than trying to integrate the TDI with the stock powertronics of a Prius, but not so impressive.
When it comes to aerodynamics and its impact to the mileage, sure a TDI Prius might beat both a Golf and a stock Prius. I'd also not disconsider some mild-hybrid approach similar to GM's eAssist and Mercedes-Benz' EQ-Boost.
