Old 10-15-2019, 09:42 AM   #2 (permalink)
Piotrsko
On the ranger, I built a pumped tank system and use a 12v 50 amp solar panel dump heating element, but it is my primary heat /defrost source. You only need pumped storage because you can expand your coolant system. You could use a car coffee heater or two to keep your tank warm. Add a high temp thermostat and waller you're golden
Otoh, isn't being warm anti efficiency?
Daox (10-16-2019)
