Old 10-21-2019, 06:17 PM   #28 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Shaneajanderson View Post
if you replace a part and it doesn't fix the problem you didn't diagnose it correctly
What about replacing some part with other out of the required specification? I have recently seen that in a '98 Mitsubishi Pajero, which had a vacuum hose replaced with a weaker one, leading it to shut down at full-throttle while cold.
Even good mechanics make mistakes/misdiagnose, but good mechanics get it right the first time the great majority of the time.
Sometimes a simpler failure might be harder to notice at a first glance...
