Old 10-25-2019, 04:46 PM   #9 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
WINTER IS COMMING
I have the gage installed temporarily, looks like Medusa's cousin is sitting on my dash, I'll get a more permanent solution built later.
Last night was upper 20'sf ambant.
68-76°compressor outlet temp @8-15psi boost.
113° peek compressor outlet temp. 81° rise
31-32°IAT at anything less than hard acceleration (not wot)
27°f under compression braking
41° peek IAT @25 mph( insufficient Ram Air) 8%hill ( medium to heavy engine loading) 3gear
312- 790° f EGT
Fully warmed up
Med throttle 8% grade 6th gear(.61 OD) 50mph 1150rpm 20 psi top1/3 radiator (above IC) blocked
Peek recall
EGT1- 860° @ standerd sopt in the manifold
CHT1-168° colent temp @radiator outlet
CHT2- 118° IAT @head post IC
CHT3- 258° charge air temp @compressor elbow..
Ive seen as high as 310° charge air temp @95mph 25psi boost the ic is suited to handle this for no more than 60sec. IAT's quickly rise to 120° w/55° ambient that is 7% loss of power w/same fuel delivery rate due to thermal expansion reducing 02 volume. Conversely last night showed it'sway too big for winter
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
slowmover (10-26-2019)
