I don't do cold. I lived in Maine for 4 years. Had my fill of snow.
Worse than snow, is the excess atmospheric warming, which is causing the jet stream to waver & at times, reach to the south. With the jet stream to the south, Arctic cold, pressured by incoming warm fronts from the south, can move to lower latitudes. Case in point, in January 2009(?) the North Pole was very warm (between 5degC & 14degC over average), heated by said warm fronts. The far north Arctic cold was powered rapidly to the south, causing Maine's lowest ever recorded low temperature of -50degF.
