Originally Posted by rob.e
Update:
I've booked for engine remap, should be mid-september i get this done.
The map runs the engine slightly leaner on part throttle (cruising) so i'm hoping to see a benefit.
Other positive of the map is it'll get me 309 ft lbs torque (418 Nm) if i need it, should make it pretty nippy i expect
I'm going to assume by "part throttle" you simply mean you are not accelerating, because diesel engines typically do not need throttles.
I also would not expect to get better mileage "leaning" the mixture at light loads because diesels always run lean; reducing the map at light load would simply reduce power forcing the driver to apply more fuel via the accelerator.
