Old 11-06-2019, 02:43 PM   #21 (permalink)
aerohead
buffer
I'm always circling back to the idea of V2G (vehicle to grid) storage schemes to help solve the problem of intermittency of power generation. Whenever you can kill 2 stones with 1 bird, it has my interest.
I wonder how much of a buffer would be reasonably available if 50% of households had EVs connected to the grid? Average household consumption rate is 1.2 kW. EVs could reasonably be expected to output 6-9 kW back to the grid, so they could support 6 households for every connected EV, and that's assuming the need to provide 100% of the electrical needs instead of some "make up" portion.
A friend is only going to attempt 1-kW (synthesized sign-wave inverter)for a power outage.It will allow for refrigerated food preservation,modest LED lighting,and communications,plus potable water pressurization from above-ground storage.
When I was 12-volt,I never knew when power outages happened.There were a few of us,and we just rocked along on without a hiccup.
By the way,complete night time grid failures are a great opportunity for astronomy.You can see really dark skies when urban light bubbles croak.
