Originally Posted by Daschicken
More info on the CVT:
If you accelerate at a normal pace, it will pretend like it has gears, but if you accelerate slowly it seems to shift once(2 speed CVT?) and then acts like the CVT it is.
The Mirage uses a JATCO CVT (Nissan's CVT supplier) that has a 2-speed subgearbox for a wider ratio. You can feel the low-high shift. But it doesn't do any "fake shifting" - it's rubber band all the time! So it's possible the Sentra uses something similar.
I was surprised how much I liked driving the CVT in
the Mirage G4 I tested out, if only because it was obvious the engineers were allowed to go pretty far to eke MPG out of the car. I loved the low-RPM cruising once up to speed - very quiet & relaxed driving experience.
