Old 11-09-2019, 01:54 PM   #421 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by 19bonestock88 View Post
How does the engine pull from so low? No bucking or shaking? Admittedly I kinda messed up my car, when I did the couple of mods to improve high RPM power it makes it a little rough from 800-1100 in 4th and 5th if you don’t roll onto it gently
Below maybe 1250rpm it's a bit rough at >75% load, but no bucking, and at lighter loads it seems fine right down to idle. As I understand it you should be able to run at high load at any RPM so long as ignition timing is correct.
And now for some hard numbers, which I'm sure people will be glad to see. Outside temperature was ~35F, sunny. Roads were mostly dry, some damp spots from melting snow. A light breeze, mostly a crosswind. Car was fully warmed up. It was difficult to tell if I was on entirely level ground at times, but these numbers might be accurate to within 2-3mpg at worst.
40mph - 55mpg
50mph - 52mpg
65mph - 47.5mpg
75mph - 43.5mpg
I expect it will respond extremely well to pulse and glide.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
MetroMPG (11-11-2019), Pressingonward (11-11-2019), Xist (11-11-2019)
