Old 11-18-2019, 08:31 PM   #60 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Well for starters, I don't have a DSG, I have a 6 speed manual, so I hold it in gear until about 3k rpm. It lost power, particularly in the above 2k rpm. On one on ramp, the procedure was: floor it in 2nd, flip on left signal, move left, shift to 3. It's now floor it, signal, shift, move left if I'm going fast enough. Couple of hp or lbft wouldn't make that much difference.
I’ve had a couple of odd reactions from my TDI over the past month under heavy throttle. The car bogs almost like it is going into limp mode with a huge drop off in power. This lasts for a couple of seconds and then power comes back.
I found a procedure online to reset the drive by wire. Since the reset I haven’t had any weird power loss AND the throttle is linear. No more turbo lag off idle followed by a torque spike at 2,000 RPM. You might want to try it
To reset drive by wire
  1. Push the throttle all the way down and hold
  2. Turn on ignition but don’t crank the engine
  3. Continue holding down the throttle for 15 seconds
  4. Turn off ignition.
The Following 2 Users Say Thank You to JSH For This Useful Post:
slowmover (11-19-2019), Xist (11-20-2019)
