Old 11-23-2019, 01:05 PM   #70 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
dang wish you told me that 5 years ago when I drilled mine. oh well have 5 more years on warranty and I think not having hydrolock is more important than a not very probable dpf failure.
BTW IT'S A DIESEL it runs lean ALL the time, kinda a diesel definition so it has no way to care about intake leaks since it doesn't have a throttle valve and has about a 50mm hole in the intake.
Wait just a minute. You drilled a hole between your MAF sensor and intake but you are blaming the dieselgate fix because your car doesn't run right?
