Old 11-23-2019, 03:08 PM   #28 (permalink)
aerohead
unibody
The Tesla is advertised as carrying 3500 lbs and towing 14,000 lbs. (I assume in high spec trims not the base one motor version.)
A current F-150 is rated to carry 3270 lbs and tow 13,200 lbs maximum. I suspect Ford can find a way to match the Tesla in the next 2-3 years.
I’m also skeptical that a unibody truck will hold up carrying those kinds of loads.
Both,longitudinally,and transversely,the unibody would have orders of magnitude larger structural triangulation and stiffness available,compared with a body-on-frame, stamped- steel chassis.And with less mass.The roof apex would act as an integral rollbar,augmenting a-pillars,b-pillars,and c-pillars in tightening,roll-over roof-crush protection standards.I don't know how you could beat it for beaming and torsional rigidity.
The Following 3 Users Say Thank You to aerohead For This Useful Post:
NeilBlanchard (11-30-2019), RedDevil (11-25-2019), slowmover (11-27-2019)
