Old 11-26-2019, 02:20 AM   #49 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by KDulcimer View Post
I'll be honest, I don't see any point in raising tire pressure. Any pressure above what the car manufacturer tells you, and you're simply eating up your tires. You'll save a penny on gas and spend 10 cents on tires.
Run it at stock pressure.
If you want to save a buck on gas, buy it in bulk whenever it's cheap. That has a LOT more to do with your cost per mile for gas than your tire pressure.
Buying bulk gas cheap sounds like a pretty good idea, but that requires preparation, a large initial investment, and continuous maintenance of a large gas tank. I'm sure it could save money given a long enough payoff period, but its probably more than most want to do.
Also, the manufacturer recommended tire pressure is usually set to optimize comfort above all else. If I followed the recommended pressure, the edges of my tires would be bald by now. I run 51 front, 47 rear. The tire pictured is a front tire with 3-4 /32nds of tread remaining. The edge wear is still outpacing the center tread. It has been run its whole life at high pressures, but has been rotated several times already.
Originally Posted by slowmover View Post
Decades experience that OVERINFLATION ruins tires and promotes premature vehicle component wear plus exacerbates unsafe handing is the test of time.
Unsafe handling is on a per vehicle basis. I get plenty of grip and predictability at high pressures.
Underinflation also ruins tires and can screw up handling.
ID:	27241   Click image for larger version
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
RedDevil (11-26-2019)
