What kind of fuel do you intend to use? Those 11:1 K20A2's are using alcohol. On a stock engine, you have to pull a lot of timing already at WOT with 87 octane which hurts both efficiency and torque.
Just as an example, on 87 octane the 9.7:1 Accord motor actually produces more torque and power (at high load) than the 10.5:1 TSX up to the point it runs out of air (somewhere around 6000rpm) because the TSX needs to run 3-5 degrees less timing with that fuel. Unless you're intending to run alcohol in your DD, I would stick with a lower compression ratio or just have boost not come on when using a low octane fuel. Higher CR helps with efficiency at part throttle but if cylinder pressures are too high (high load + high CR + boost) you have to retard timing such that you're sending a lot of unused energy out the exhaust.
