After fixing the buttons, I can now adjust the contrast. Turning it to 7 makes it where I can read "Contrast 00000007". But then what? The other half of the LCD still shows white blocks. Should it? How do I go on to another screen?
Edit - Okay I went an found instructions. I can't see a "XX" or "OK". But by positioning the cursor on my first digit and then going one more left, I was able to use it anyway. So I got through the setup screen. Now I guess the thing is working. The screen is a little glitchy and isn't always readable, but it is showing I 000.00 and C 000.38
Edit - When I took it back to the car to take pictures, it was back uncontrasted and I couldn't set it again. So now I've gone into the program and made all of my settings the defaults in the hopes that it will now start up right. I'll go take some pictures now if I can, but basically the right half of the screen stays white blocks except for the occasional wiggling glitch.
