Old 12-14-2019, 08:54 PM   #244 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
No it won't, and there are F150s available with 3270 pounds of payload. I'll bet the GVWR on the Cybertruck is at least 9000 pounds, I actually believe thy will just go straight to 10,000 pounds and not mess around. I bet any 4wd outweighs my 2001 3/4 ton 4x4 Suburban that has Cybertruck type payload numbers.
I'm all for making the Cybertruck but just don't get all the fairyland beliefs surrounding it.
What current truck owners don't understand is efficiency
Going from a floppy ladder frame to a unibody saves 1/2 ton of weight while being much, much stronger. American pickup payloads are laughed at in the rest of the world. An exoskeleton/ space frame is stronger still. When you have a fundamentally strong design, you can use lighter materials.
A truss bridge like this has a weight capacity of ~200tons:
Remove all the structure, leaving just the deck in place, and that's your typical pick up. ~10 tons capacity. Restoring the bridges capacity to 200 tons using just the deck girders would make the bridge extremely heavy.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
aerohead (12-18-2019)
