Couple clarifications:
Once the values make it into the eprom (when you make it through all the setup screens) the program defaults are ignored.
Also the valid values for contrast are 0 to 255. The wrap around at 255 so Wyatts mention of 315 above is really a 60. Not a lot of room for a fancy editor so that's what is going on there.
Ax, I suspect one of your lcd lines isn't set up right. Which model did you have again?
