Old 12-18-2019, 01:07 AM   #436 (permalink)
MakitaDiesel
The Practical Modder
MakitaDiesel's Avatar
Thunder - '85 Honda CRX Si
90 day: 44.84 mpg (US)
Lightning - '89 Honda CRX HF
Last 3: 46.25 mpg (US)
The Darkness - '97 Honda Civic DX
90 day: 41.84 mpg (US)
I copied this from a post you made on the K swapped FB page 3 weeks back.
Converting your Kpro maps to similar Ktuner maps has quickly become more daunting than I expected. It's like trying to play Halo on a PlayStation or translating old English into IKEA instructions. After skimming through your parameters I had a couple questions: why not use stock knock control logic? I assume you tuned on either 89 or 91. We seem to have 87, 89, and 93 here.
I plan to also change the gear comp as I have a 5-speed with a 4.3 diff and tweak speedo correction.
When you say add fuel and pull timing to use as a starting point on a similar engine, do you mean pull 2° and add (x?) fuel everywhere or just the last 3 columns? I'll understand more (and have more questions) once I actually start the process and datalog on a moving car.
The Following User Says Thank You to MakitaDiesel For This Useful Post:
Ecky (12-18-2019)
