Drive win it is snowing. The snow packs into stagnation points. Modifying the shape until a laminar layer develops guiding the fresh sticky snowflakes around the stagnation/impact point.
I think you will find that the snow will pack in were the road grim is . If the radius was too tight I would have expected to see recirculation / patterns like i see in the upper section
Unless you have an affinity for symmetry I would try moving both openings in the grill block to the inlet side of the radiator for better Delta T when cooling, this might also help with warmup times. You have the equipment to test. Use the scan tool and pin a land mark to the point it hits 90% thermostat open temp and first close with various startup temps. If your log will give you mi/time stamps that makes it easier.
I think your test is good enouph for a dose it work, but as stated multiple runs (3-5) avg would give a more accurate how much. Also how many mi run before testing? Cold diff oil ect. can have a large impact on results
Dream Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
