Old 02-01-2019, 12:32 AM   #11 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Wouldn't leaving the middle two open provide more of a cooling benefit? Or is the point to leave those covered?
The Following User Says Thank You to Taylor95 For This Useful Post:
fastflyer (01-17-2020)
Old 02-03-2019, 04:04 AM   #12 (permalink)
AdrianD's Avatar
I don't know, the only discussion I've found about what openings to leave open is for an XJ which has the viscous fan and the owner openings in front of the viscous fan open for correct viscous fan operation.
My Jeep has a hydraulically operated fan, so no need for that.
Old 02-10-2019, 01:33 PM   #13 (permalink)
AdrianD's Avatar
Trip done, now for some numbers:
First tank, over 393 miles of highway (reference section) - 31.65 calculated MPG, 35.1 indicated MPG
Second tank, over 425 miles of highway and 120 miles of mountain roads (commute to the ski slope) - 28.2 calculated MPG
Third tank, over 457 miles of highway - 29.66 calculated MPG - strong side winds
Average MPG over 1396 miles - 29.586, indicated MPG: 33.128.
In L/100km, the difference between indicated to calculated consumption was 0.7L/100km for the first tank and 0.8L/100km for the trip total.
The trip from 2016 had an average MPG of 29.549. For that trip I had a stronger chin spoiler and the lower grille block.
You can see here that the chin spoiler bent back. I will modify the mounts to make it stronger and easier to install/uninstall:
Here it's obvious that there is a lot of road spray on the chin spoiler and almost nothing on the tire deflector past the bend. Should there be spray there to show attached air flow? Corner wear from tire contact is also visible:
This is how far back the deflector is pushed when going up to 85 mph, the highway was very busy and sometimes passing trucks required going that fast.
Back to the drawing board for the deflectors. I'm open to suggestions
The Following 2 Users Say Thank You to AdrianD For This Useful Post:
aerohead (12-26-2019), BamZipPow (02-11-2019)
Old 02-10-2019, 01:43 PM   #14 (permalink)
AdrianD's Avatar
Also, I'm an idiot with the grille block, I should've read this first:
https://ecomodder.com/forum/showthre...ary-13768.html
Old 02-10-2019, 03:00 PM   #15 (permalink)
Turnbuckles.
You can't be wise and in love at the same time. -- Bob Dylan
Old 02-10-2019, 03:04 PM   #16 (permalink)
AdrianD's Avatar
That thing looks bad-ass
Old 02-10-2019, 05:17 PM   #17 (permalink)
It's easier when you start with a Beetle.
It's not streetable, in fact they had to remove the splitter to get it on and off their trailer.
Old 02-11-2019, 02:46 AM   #18 (permalink)
AdrianD's Avatar
I remember reading the topic with that.
Honestly, I don't know if the car felt more stable at highway speeds because of the deflectors or because I replaced some worn control arm bushings
The Following User Says Thank You to AdrianD For This Useful Post:
aerohead (01-02-2020)
Old 12-19-2019, 03:02 AM   #19 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Drive win it is snowing. The snow packs into stagnation points. Modifying the shape until a laminar layer develops guiding the fresh sticky snowflakes around the stagnation/impact point.
I think you will find that the snow will pack in were the road grim is . If the radius was too tight I would have expected to see recirculation / patterns like i see in the upper section
Unless you have an affinity for symmetry I would try moving both openings in the grill block to the inlet side of the radiator for better Delta T when cooling, this might also help with warmup times. You have the equipment to test. Use the scan tool and pin a land mark to the point it hits 90% thermostat open temp and first close with various startup temps. If your log will give you mi/time stamps that makes it easier.
I think your test is good enouph for a dose it work, but as stated multiple runs (3-5) avg would give a more accurate how much. Also how many mi run before testing? Cold diff oil ect. can have a large impact on results
Dream Big Chisel Down To Reality
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-19-2019, 08:32 AM   #20 (permalink)
Don't kick yourself too hard, anyone that's done the block before could have spoken up earlier on.
As for myself, I do not like grille blocks as I had an overheating issue back in 1983 when I tried my first one. There were no rules or guidelines back then, and no Internet.
Funny that #1 and #2 rules would have changed things had they been followed.
