12-19-2019, 03:37 PM
#7988 (permalink)
https://en.wikipedia.org/wiki/Oscillating_water_column
Oscillating water columns (OWCs) are a type of Wave Energy Converter (WEC)[1] that harness energy from the oscillation of the seawater inside a chamber or hollow caused by the action of waves. OWCs have shown promise as a renewable energy source with low environmental impact... OWC are devices with a semi-submerged chamber or hollow open to the sea below, keeping a trapped air pocket above a water column. Waves force the column to act like a piston, moving up and down, forcing the air out of the chamber and back into it. This continuous movement force a bidirectional stream of high-velocity air, which is channelled through a Power-Take-Off (PTO). The PTO system converts the airflow into energy. In models that convert airflow to electricity, the PTO system consists of a bidirectional turbine. This means that the turbine always spins the same direction regardless of the direction of airflow, allowing for energy to be continuously generated.
https://en.wikipedia.org/wiki/Hydraulic_ram
A hydraulic ram, or hydram, is a cyclic water pump powered by hydropower. It takes in water at one "hydraulic head" (pressure) and flow rate, and outputs water at a higher hydraulic head and lower flow rate. The device uses the water hammer effect to develop pressure that allows a portion of the input water that powers the pump to be lifted to a point higher than where the water originally started. The hydraulic ram is sometimes used in remote areas, where there is both a source of low-head hydropower and a need for pumping water to a destination higher in elevation than the source. In this situation, the ram is often useful, since it requires no outside source of power other than the kinetic energy of flowing water.
The oscillating water column is billed as a wave power solution, but I think the principle applies to tidal power as well. The Hydraulic ram could be used to lift water above high tide.
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..I before E, except after C -- trust the Science
